2 members (Joe H, Naturalthud), 196 guests, and 0 robots.
Topics128,080
Posts1,056,062
Members48,433
#1377892 09/21/2020 3:40 PM
I want to check the clearence in the rod and crank bearings in my 1954 235. Before I drop my oil pan, is it possible to access the front crank bearing without removing the front motor mount? It looks like it might be in the way.
It's been done thousands of times. There is one position that the crankshaft needs to be turned to allow the main cap to tilt and clear the motor mount. That procedure was discussed just a few days ago in another thread.
Good to know. I had done search, but didn't see anything. Thanks.
That discussion is in the "My 261 makes noise" thread, which is maybe a page off the front by now.
I have the bolts removed from the front bearing cap and it is loose, but something is holding it on the left side and it will not come down.
Did you remove the two bolts that go forward into the timing cover? They have 1/2" hex heads, and I believe there is a locking tab that must be bent away from the bolt heads to get a wrench onto the bolts. Sometimes it's necessary to pry or tap on the cap, as there is a gasket between the cap and the timing cover that can stick them together if sealer was used when the cover was installed.
Yes, I removed the 1/2 inch bolts. The cap is loose. The right side is completely free, the left side will only come down about 1/8 inch. I can slide it forward and back, but it will not come down. It does not appear to be hitting the crank.
The crankshaft has to be positioned so the bottom of the cap can be tilted toward the back. It's a close fit, but it can be done.
Check the photo on page 1 of this thread showing the position of the crankshaft:
https://www.stovebolt.com/ubbthread...1/horrible-sound-from-my-261-part-2.html
As a last resort, unbolt the front motor mount and jack the engine up a little.
Good info. Not sure why I couldn't find that thread. Thanks Jerry.
