| | | Forums66 Topics128,128 Posts1,056,683 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Was thinking of disc brakes on the stock 49. Watched a few videos and although all kit manufacturers claim they are bolt on it appears not quite so. On the Brothers video the talk about checking for clearance between the caliper and the wheel rim. But they don't say what to do if it rubs. Also it seems that there can be clearance issues between the caliper and the tie rod ends. Then it states that you have to use the existing hubs. Are there any kits that are true bolt-in? Have the same question for dual master cylinder upgrade. | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Don’t think there’s any thing that is true “bolt on”.........things like drill hole, change a brackets and shim a part are all part of the game. Of course Bend and reroute brake lines is also part of the game. Classic Performance Parts hub kit came with roller bearing there was 1 hole that had to enlarged. ( that was several years back.) https://www.classicperform.com/Store2/Suspension/4759RBH-KDI.htmAs far a wheel clearance to the caliper or tie rod most of those issue are with 15” rims. | | | | | Joined: Jun 2020 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2020 Posts: 37 | My Classic Performance Parts kit for the stock hubs was about as close to true bolt on as I could find for my 65. I had to grind on the caliper brackets a little to fit around anomalies in the spindle.
FYI... their prebent brake line kits are by the hair of a gnats butt. | | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | Put Classic Performance Parts disc brakes on my stock 49-3100 two years ago. Could not be happier with the kit and performance. Kit went on with no modifications. I had to get new wheels to compensate for the off set I knew that before I started so I was ready with the new wheels. | | |
