2 members (ChevyBlue, Otto Skorzeny), 224 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
Page 2 of 2 1 2
#137756 05/16/2007 2:11 PM
hay man, I'm a teacher, we have very little money.. though berthoud is not too far away...
maybe we need to do a colorado bolter gtg...
"I'd rather have a bottle in front of me than a frontal lobotomy."
-D. Parker
1951 Chevy 3100
#137757 05/16/2007 2:39 PM
I just spoke to my chevy guru friend, he said if I need to mod the steering components it's nothing a grinder and a torch can't fix..considering all of the things he has built for the drag strip...I trust him, my bolt will never be going 120+mph..
-D. Parker
1951 Chevy 3100
#137758 05/16/2007 6:00 PM
Hey CoolethanEthan, or mike1951, after you do this swap, let us know the in's & out's with the steering and things. I think I'm going to contact the axle guy also. Thanks for the pics of that axle. Looks nice.
#137759 05/16/2007 8:10 PM
I will photo document the process.
MAybe ethan and I can work on a tech section article...
-D. Parker
1951 Chevy 3100
#137760 05/17/2007 5:53 AM
Easyest way to lower it is to drive it til the wheels fall off grin
GMC: Get More Cash...
1958 GMC
My Webshots photos
#137761 05/17/2007 2:21 PM
I am in the process of doin that...
My 51 is the only vehicle I have smile
-D. Parker
1951 Chevy 3100
#137762 05/18/2007 1:38 PM
"maybe we need to do a colorado bolter gtg..."
i wonder how many of us there are?
i miss obscene phone calls...
#137763 05/18/2007 1:59 PM
I need to swap my rear for a 3.55 to 1 before any long distance driving happens... 50 mph is fun... really... luckily my work is about 2 miles from my house...
-D. Parker
1951 Chevy 3100
#137764 05/19/2007 3:18 PM
....and i'd have to get one running;)
hey, i got a 3.25 geared posi disc brake rear out of a 87 iroc that's allready got the brackets cut off....make ya a helluva deal on it;)
#137765 05/19/2007 11:39 PM
is it 6 lug? smile
-D. Parker
1951 Chevy 3100
#137766 05/20/2007 3:27 PM
nope,5X 4 3/4"
hey, get a hold of a circle track catalog.
they have all kinds of weldon caliper brackets and maybe use rotors off of a late model PU like my 2000 4X4....
#137767 05/22/2007 5:50 AM
my axle arrived, I will document the lowering process in june when I get to it
-D. Parker
1951 Chevy 3100
#137768 06/07/2007 6:40 AM
Ethan is almost done with his swap...
however the drag link seems to be giving him some problems... he mounted the tie rod on top of the leaf springs and the drag link is having clearance issues with the tie rod...
I have heard that you need to heat the spindles and adjust them so the tie rod fits back under the leaf springs...
is this the case? If so does anyone have photos?
-D. Parker
1951 Chevy 3100
#137769 06/08/2007 5:07 PM
Normally with a dropped axle you'd install the tierods upside down so they mount into the bottom of the steering arms.
#137770 06/13/2007 3:21 PM
ok everything is torn apart...
I have been removing 50+ years of grease and grime...My bushings are getting pressed into the spindles at the moment..I am now a king pin removal pro
-D. Parker
1951 Chevy 3100
#137772 06/14/2007 1:56 AM
I have 16s on there I checked they will clear...
with the stock set up, I can get upder there and change the oil without jack stands...
-D. Parker
1951 Chevy 3100
#137773 06/20/2007 8:50 PM
almost finished.... repack the bearings, adjust the brakes and put it on it's wheels
-D. Parker
1951 Chevy 3100
#137774 06/21/2007 4:48 AM
Those axles look real nice. I have seen dropped axles that looked like a friggin piece of taffy stretched. That one looks great. I may just get one from him as well.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#137775 06/21/2007 6:30 AM
Here is a post from Sid.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=29;t=003228
#137776 06/30/2007 11:04 PM
sid's axles are professionally done...
the biggest issue I had was the steering geometry..
not sid's fault...
I am getting 3.5 inches removed from the pitman arm and all my problems will go away
-D. Parker
1951 Chevy 3100
#137777 07/02/2007 2:51 AM
a few pic of the progress...
I got the seat upholstered...
and you can see the stance... the wheel tucks nice... It's got a set of jack stands under the axle..
IMG]http://i95.photobucket.com/albums/l129/mikelamphere/102-0293_IMG.jpg[/IMG]
[img]http://i95.photobucket.com/albums/l129/mikelamphere/102-0298_IMG.jpg[/img]
-D. Parker
1951 Chevy 3100
#137778 07/14/2007 6:31 PM
Is that dropped axle AND dropped springs? Looks like more than I'm after for mine, but I'm considering one or the other...
Page 2 of 2 1 2
