| | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Many years ago I bought one from Jim Carter Truck Parts and from Chevs of the 40s.
Your ad in the Swap Meet might get a response. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | They have been kind of hard to find lately, I had an extra but sold it to a guy in the land down under a few months ago. He was on the hunt for one for quite awhile.
Might try these guys , spendy but complete: https://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z58622~P349.50~~~~S4IG0OOGLT10889311880d~Z5Z5Z5~Z5Z5Z50000014x 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Jim Carters' used parts department is closed because of "Kung Fu" flu. I suppose I could try again and plead with them.
Walt | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Good News
I decided to take the u-joint yoke to a driveline shop to see what they can do. They said that they could recondition the yoke by welding the gouged out spots and make the u-joint bushings seats flat again. Where I do not seem to have any other option they are currently working on it. I suspect this process will take a day or two.
It will make it so I can bolt the u-joint to the yoke. I will use thread-locker compound and safety-wire it to prevent this from happening again. | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Best place to find one of those is in a junkyard. Very hard part to locate. When I did my 3-speed to 4-speed swap in my 3100, that part stopped me dead in my tracks. Luckily, a fellow Stovebolt member picked up a chassis/driveline that had the yoke still intact, and sent the yoke and clips/bolts to me.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
