1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | good afternoon, i have a 1937 chevrolet carry all, i need the front bearings (inner and outer) and the seals for each side. where can i get them? ebay, jim carter, napa, local auto parts stores doesnt have them. thanks in advanced. | | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | | | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | sold out of the big one.. | | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | sold out of the big one.. Did you scroll down to the bottom of that page?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | original seals are leather pressed in metal. there are several of the vintage parts locations that have them. I wanted neoprene so I went to napa and they were able to mic and find some but were special order and were going to run me near $50.00 ea.! went to local bearing/seal and hydraulic hose supply house and they found CR seals SKF 18258 that ran me around $12.00. as for bearings, they are ball bearings, again available from our vintage guys, but there are modern roller bearing with race kits available to fit and replace the originals. tempted but haven't done it. check prices, some are ridiculus, others more reasonable.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | oldmemoriescc,
Bearing and seal originals and upgrade replacemnts are easily looked up in a bearing and seal catalog if you have their ID, OD and width. There are many. many bearing sellers in LA and I've found that they get new catalogs at frequent intervals and are happy to give customers their old catalogs. Now I can look bearing and seal numbers at home.
For my '36 PU I found all the bearings and seals I needed in LA, no sweat. Also made in USA bearings are out there so it's possible to avoid manure made in China.
Ray W
Ray
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | A lot of the bearing manufacturers have their bearing specs online. | | |
