| | | Forums66 Topics128,085 Posts1,056,091 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 6 Junior Member | | Junior Member Joined: May 2005 Posts: 6 | Hi Guys, I am interested in putting a later model Saginaw steering box, either manual or power would be nice in my 1936 Chevy pickup and would like to know if anyone has knowledge of this and the best box to get. I want a box that the steering shaft fits thru the side of the frame like the original. Any and all advise is appreciated. Thanks...Richard | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I once owned a '36 Chevy car, but don't recall ever looking under the hood of a '36 pickup. I don't think you'll find a recent steering box that is anything approaching the configuration of your original box.
Why do you want to change?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | A good choice for a better gear box is the '40 - '46 Chevrolet truck. It will bolt a '37, I assume the '36 is the same, anyway it has ball bearing rollers inside so it steers a lot easyer then the early boxes. Joe | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I think that would be 41-46 chevy or gmc | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | You are right, I was a year off. The steering wheel from a '40 would work, the look like the older truck, but have the right spline for the newer shaft, I think! Joe | | |
