| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | I’m getting my axle back in this week after doing the P30 spindle swap. I need to get new shock absorbers. Can anyone tell me where I can find a set? Part numbers? I have a 56 4500 short school bus. Thanks. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | If you still have the original shocks you can measure the compressed and extended lengths and call Monroe's tech line and they can convert to a modern number...I just did this for my M38A1 Willys Jeep. Mike B  | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | | | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | If you still have the old ones there were numbers stamped on my old ones that helped me. | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | I did try that, but did not get much info come up on a search. I will try Mike's suggestion and see what I find out. | | |
