7 members (stlcardinalsguy, Maybellene, Wally / Montana, Wheelie, Otto Skorzeny, Gdads51, MarkT),
188
Mod | | | Forums66 Topics128,078 Posts1,056,022 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 41 | I have a 1952 3100 5 window I am restoring. It was running fine but recently when I try to back up, it is almost like it locked up. Not sure if it is a sticky clutch (4-speed on the floor). Any suggestions or help would be very much appreciated. I would like to figure it out and get it fixed before I put it back together. | | | | | Joined: May 2015 Posts: 11,063 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,063 | Can you move it forward? If so, it wouldn't be a clutch problem. And also not necessarily a transmission problem. I would look at brakes. Possibly one of the shoes has stuck to the drum and won't let it turn.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | I would also suspect a brake problem.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Drop the rear end cover plate and inspect the cross pin that holds the spider gears in place. If the lock bolt for that pin breaks or backs out, the pin can slide out and lock up against the rear end housing. You'll be able to get a little movement, but considerably less than half a turn of the rear wheels. Jerry
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | All good suggestions already posted. But the question i have is. With the truck in neutral, will it roll then? If not, its probably differential or brake issues as mentioned. | | |
