0 members (), 79 guests, and 0 robots.
Topics128,035
Posts1,055,560
#1376314 09/07/2020 10:39 PM
I have a 1951 truck that I have stripped down to the frame. I have unbolted the cab mounts and have wondered if anybody has updated the rear cab shackle mounts for a more modern urethane mount from maybe an S10 or Ranger? Does anybody see an advantage to keeping the shackle mounts? I don’t think it would take much modification to change them out. Thanks for your ideas.
FL_51Chevy #1376435 09/09/2020 12:16 AM
Most of the popular aftermarket suppliers offer a bed mount kit that includes all new bushings, rubber pads and hardware to rebuild your existing front and rear cab mounts, and is reasonably priced. Much easier than re-engineering mounts that have worked successfully for many, many years. Just a suggestion.
Charlie
'51 3100 5-Window (Restomod in progress)
A 51 frame is designed to have a great deal of flex in it. That is why the cabs are mounted on shackles. It is what prevents cab sheet metal fatigue damage to the cab when going over rough terrain.
S10s and Rangers frames do not flex, therefor they do not require shackle mounts.
FL_51Chevy #1376471 09/09/2020 10:46 AM
I ordered the bushing but my mechanic welded the shackles solid frown. ???????????
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I've thought about modifying the factory cab mounts on my 54. Th initial thought process was too use a biscuit style motor mount. The factory cab shackles actually do a pretty good job when it comes to absorbing shock and vibration. A better solution would be to modify the front cab mounts. The OE mount is basically justa chunk of rubber with a bolt through it. The trick is finding mount that is internally tied, so your cab stays on the frame when the rubber wears out.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
