8 members (Stovebolt48, 1955 1 Series, Bill Hanlon, fonz8261, latroca52, klhansen, JoergK., 1 invisible), 110 guests, and 1 robot.
Topics128,195
Posts1,057,373
Members48,469
#1376315 09/07/2020 10:45 PM
Hi all, can’t figure out why my choke cable won’t open or close choke plate, this on a one barrel Rochester, I can open and close choke plate using my finger I’ve not had this carb apart. Pretty sure I have connected cable the right way.
Dane Walton #1376333 09/08/2020 1:34 AM
Chuckle... chuckle... this is atad bit funny, but all in all we alp started somewhere.. So that being said, we dont have enough info on the application etc. But if i had to guess, ill give you something to look at anyhow. Undo the choke cable from the carb. Does the cable move free? Does the choke plate move free? If either answer is , no, fix either or. If both answers are yes, you have it hooked up wrong. Open choke all the way in the carb, push choke cable in and hook it up to the carb. Pull it. Does the choke work? Let us know what you found. ohwell
Dane Walton #1376336 09/08/2020 1:59 AM
Dane,
What are you working with (yr, engine, carb, air cleaner). This is an easy mechanical system to fix. Just give us a little bit more info. Other things to consider in the meantime:
Tech is to depress throttle as you pull the cable. It allows the choke cable to miss the throttle linkage.
Cable could be crimped somewhere along the route.
In my case the eye that the cable passes through at the carb hits the underside of my air cleaner and does not allow the cable to move freely.
Maybe something else, but no doubt easy to fix.
HB
~ HB
1962 Chevrolet C10
1962 Suburban
Dane Walton #1376349 09/08/2020 6:59 AM
In addition to the possibility of a crimped cable and some sort of mechanical interference, check for corrosion anywhere along the length of the cable. It doesn't take much too rust inside the sheath for the wire to bind up... If you find this is the case, you can pull out the wire, coat it with light grease and re-insert. It should then operate freely.
Dane Walton #1376350 09/08/2020 8:19 AM
If tomctomc is correct, you might want to remove the cable-assembly and soak it in kerosene for a day or two?
Dane Walton #1376452 09/09/2020 2:05 AM
I have had good luck with spraying the outer cable sheath with penetrating oil. It is nothing more than tightly wound spring steel and the penetrating oil goes right through it to the cable wire inside.
