9 members (55shaker, Gdads51, dwreills, chevy51truck, Phak1, klhansen, 52Carl, KEVINSKI, 1 invisible),
121
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi Guys, I have a 1950 1/2 ton converted to 12v. What is the largest size battery that can fit in the battery trey/box? I need a new battery and have always used these very small size battery and if possible I would like to get a larger one. thanks, skipper | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | I put a NAPA 8458 in my 49-3100--just fits--Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Those dimensions would be: Height 6.875 in Length 10 in Width 7.25 in | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | I would be more concerned with having a battery that gives me the CCA's that are needed. But a small battery in a big box kind of looks funny.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Get a Optima, a little expensive but my last one lasted 13 years then I purchased another one. I got a red top. But they have deep cycle. Us Tim's measurements.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 6v Optima battery is a nice fit in the 47-55st battery box. It has to be placed on a diagonal inside the box. They most likely have a 12v battery with similar dimensions (see below)? Here are the 6v Optima dimensions: Model: 6V Width: 3.63 in Length: 10.06 in Height: 8.13 in Here are three pages of all Optima REDTOP battery dimensions.(click through the dots/buttons near the bottom of each page, to see the three pages). | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I believe mine was the 34. I have one made by another company that Auto Zone sells that is a little cheaper. I bought mine 4 years ago. I think the company is Penn.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Optima 12 Model: 34
Ron, What truck-year battery compartment did you put that in? Did you have to "adapt" anything to get it to fit?
Weight: 37.9 lb C20 Capacity: 50 Ah Post Type: SAE Post CCA: 800 Amp Width: 6.88 in Length: 10.06 in Height: 7.88 in | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Hello guys, I extended the length of my battery box to hold two in series deep cycle batteries. They fit through the original battery cavity under the battery lid in the floor just fine. I then put an automatic switch under the dash that goes to all six volt systems. this way I can run a 12 volt a/c, on the firewall I have two lugs, one is 6 volt the other is 12. I can charge it on twelve or six volt. The 6 volt generator works well and the starter (6 volt), turns like it has a twelve volt battery. Four years and still going strong. If anyone wants a hand drawn schematic and pictures give me a day or so. Ed
| | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi Doc, yes I would like to see the schematic as I do not follow how you are doing this. I measured the the inside of my battery box and it is 7" x 9- 7/16". I have a 1950 so maybe it is different than the later models? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
| | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | I used a group 24 battery. There is a bit of room left over. Group 24 seems to be the most common size, so lots of deals to be had. I glued rubber to the underside of the cover. Probably not needed, but I really don't like short circuits! https://shop.advanceautoparts.com/r/advice/car-maintenance/car-battery-size-chart
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | According to the battery chart, the group 24 is 10 1/4" length. I remeasured my box again and I see there are rivets that hole the upright threaded rods. So, it is actually smaller that I had said previous, it is more like 9-5/16" between the rivets. Gord, what year is your truck? | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Ok, ignore my comment. I just took a look at the truck; my battery box was modified.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The group 35 should work, I have room to spare.
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | rc365s, I will draw it out on the drawing board and send it to you. It will take a few days, I'm away until tomorrow. Ed
| | | | | Joined: Sep 2010 Posts: 68 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 68 | Agree with WE b OLD, The Red Top Optima Model 3478DT Red 34/78 fits well in the original battery box of our 1952 Chevy 1/2 ton pickup. A bit snug but like it that way. This battery has a CA of 1000 and a CCA of 800. Just replaced it this year with the original lasting 10 years. The size is 6 3/4 by 10 with a height of 7 inches. I cannot use the original hold down because I use a battery disconnect that I can reach from reaching up from below the running board to disconnect the battery during storage. Don't have to remove sill plate or take up floor mat to disconnect. Hope helps. Chuck 52 | | |
