1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1376168 09/06/2020 8:23 PM
Does anyone know where I can find the gasket that fits the intake manifold under the carburetor insulator for a 235? LMC, Classic Chevy Truck Parts, Mikes Carburetor, etc. does not have them. Almost all of us can make a gasket but, it is so much nicer to have one ready made. About .0870 of an inch. Doc.
Doc.Hall #1376169 09/06/2020 8:26 PM
Originally there was no gasket.
I have always felt that putting a gasket there can cause the insulator to crack.
A little gasket sealer is okay.
My Blog
Doc.Hall #1376203 09/07/2020 12:26 AM
truck shop in orange ca usually has them
This is no longer fun
Doc.Hall #1376204 09/07/2020 12:26 AM
Why can't you just use the same gasket which goes between the carburetor and the spacer?
Doc.Hall #1376237 09/07/2020 3:54 AM
H Online: Content
The stud length usually doesn't allow a thick gasket to be used. Is it really necessary to use a gasket under a phenolic block? I always wet-sand the insulator block on a piece of plate glass to make sure it's flat on the top and bottom, and don't use a gasket on the intake manifold side.
