| | | Forums66 Topics128,154 Posts1,056,831 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 9 New Guy | | New Guy Joined: Jul 2020 Posts: 9 | So i bought this 47 2 ton. I got it running. Now times for brakes. So i want to go through the entire system. My question is ....there is a hydroboost on there I am told. Is it really a hydro? Isn't it more of an old school vacuum booster. I am debating getting rid of that and just using a master cylinder with a 1.25 or 1.5 bore with a 7 " vacuum booster on it. How much psi does that original booster give out psi wise? 1000?800?1200? What have many of you guys done for brake systems. | | | | | Joined: Sep 2011 Posts: 1,458 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,458 | Hydro- boost it is not. Hydro- boost runs off power steering pump, mounted between master cylinder & firewall, didn't come out until 1973 . What you have is hyrdo-vac, booster is normal mounted under cab on frame rail.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Your truck should have a Hydrovac booster mounted on the frame. It is a large canister with vacuum and brake lines going to it. If memory serves me they add about 900 psi to your stopping pressure. If you decide to put a modern dual pot master cylinder on your truck in place of the original, make sure the master cylinder bores are the same size. My trucks all have the stock systems and do just fine, but they are also 100% new parts, including the lines and hoses. Mike B  | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If you eliminate the Hydro vac you will have very little braking power. If you want your truck to have good brakes, bite the bullet and fix everything and have the hydro vac rebuilt by a competent shop. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If you eliminate the Hydro vac you will have very little braking power. If you want your truck to have good brakes, bite the bullet and fix everything and have the hydro vac rebuilt by a competent shop. | | | | | Joined: Sep 2019 Posts: 204 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 204 | If you have the hydrovac rebuilt I would recommend Cardone. NAPA will ship it for you and they'll box it for you too. I had my hydrovac rebuilt by them and they did a excellent job plus a 1 year warranty | | |
