0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#1374366 08/22/2020 1:53 AM
I have a 1950 Chevy 1 1/2 ton truck and I need to know if it’s a loadmaster or thriftmaster ?
1950 4400
My '47 1 1/2 ton is a Loadmaster.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Those terms refer to the engine, not necessarily the truck. A "Thriftmaster" is a 216, and a "Loadmaster" is a spray-oiler 235. Look at the block casting number and/or the stamped number behind the distributor to figure out which engine your truck has.
Load-Master and Thrift-Master are actually engine references that correspond to model designations. A Load-Master being a 235 equipped truck and a Thrift-Master being a 216 engined truck. The Heavy-Duty 235, Option number 225 (different letter codes depending on model) was available in 4400 series trucks (1-1/2 ton nominal rating). The 4400 Series trucks are equipped with the 216 as standard in 1950.
https://www.flickr.com/photos/advance-design_parts_co/50255205127/in/album-72157631872034068/
https://www.flickr.com/photos/advance-design_parts_co/8250843887/in/album-72157632186114015/
https://www.flickr.com/photos/advance-design_parts_co/8250844293/in/album-72157632186114015/
Didn't the hood side emblems on the 1947-1948 4000 + series say "Loadmaster" regardless of the engine installed? If so, a 4000 series truck could've had a "Loadmaster" emblem and a "Thrift-Master" engine.
1948 THRIFTMASTER & LOADMASTER trucks and engines and standard engines:
http://chevy.oldcarmanualproject.com/chevyresto/4886.htm
The 4000 series trucks could have an RPO 235 engine.
Maybe that changed the side emblem on that series from ThriftMaster to Loadmaster?
Mine has the Loadmaster emblem on the side of the truck. The engine itself was replaced long ago.
Rich
1947 Loadmaster
A 4400 series 1 1/2 ton truck, equipped with a 216 Thriftmaster engine, is a Thriftmaster truck. If 47, or 48 model, it would have the "Thriftmaster " emblems on it. All 2 ton trucks came standard with the 235 Loadmaster engine, and had "Loadmaster" emblems in 47, and 48.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Thanks, Spanky
My truck has a 216 so I have a Thriftmaster. Dad had a 52 also I remember it having a Loadmaster emblem on the hood but he sold it before he died. Thanks for the info guys.
1950 4400
