0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 11 New Guy | | New Guy Joined: Sep 2008 Posts: 11 | Just started work on my new project , just took the back brake drums off 16 inch diameter discovering that I need the shoes relining could anybody please tell me how thick the new linings should be, | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy madtrucker, welcome, I believe brake shoes up to four inch wide use brake lining that is 3/8" thick, shoes that are five inches wide use lining that is 1/2" thick, hope that helps. | | | | | Joined: Sep 2008 Posts: 11 New Guy | | New Guy Joined: Sep 2008 Posts: 11 | | | | | | Joined: May 2009 Posts: 136 'Bolter | | 'Bolter Joined: May 2009 Posts: 136 | Jim Carter offers a re-lining service for those. I have linings to sell that are the correct 16 X 3 linings with rivet holes.
Mike Russell 573 592 1991 work 573 864 6539 mobile | | | | | Joined: Sep 2008 Posts: 11 New Guy | | New Guy Joined: Sep 2008 Posts: 11 | Thanks for info but I'm in UK so just need to know the correct thickness if you could let me know please many thanks rob | | | | | Joined: Jul 2018 Posts: 3 New Guy | | New Guy Joined: Jul 2018 Posts: 3 | Hello- IIm also getting a truck moving again and im in need of some brake parts. 35 Mike, do you have different size linings? I"ll measure mine and get with you.
| | | | | Joined: Sep 2020 Posts: 53 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 53 | I am in the process of doing brakes on my 42 ton and a half. Shoes are at a local shop in NC. Will get them back this week and I will ask them what they used. These guys have a great reputation and they will know for sure.
Bah
