7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf),
74
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | I have a 1950 Chevy 1 1/2 ton truck and I need to know if it’s a loadmaster or thriftmaster ?
1950 4400
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | My '47 1 1/2 ton is a Loadmaster. | | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | Those terms refer to the engine, not necessarily the truck. A "Thriftmaster" is a 216, and a "Loadmaster" is a spray-oiler 235. Look at the block casting number and/or the stamped number behind the distributor to figure out which engine your truck has. Jerry
| | | | | Joined: Sep 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 32 | Didn't the hood side emblems on the 1947-1948 4000 + series say "Loadmaster" regardless of the engine installed? If so, a 4000 series truck could've had a "Loadmaster" emblem and a "Thrift-Master" engine. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1948 THRIFTMASTER & LOADMASTER trucks and engines and standard engines: http://chevy.oldcarmanualproject.com/chevyresto/4886.htmThe 4000 series trucks could have an RPO 235 engine. Maybe that changed the side emblem on that series from ThriftMaster to Loadmaster? | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Mine has the Loadmaster emblem on the side of the truck. The engine itself was replaced long ago. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | A 4400 series 1 1/2 ton truck, equipped with a 216 Thriftmaster engine, is a Thriftmaster truck. If 47, or 48 model, it would have the "Thriftmaster " emblems on it. All 2 ton trucks came standard with the 235 Loadmaster engine, and had "Loadmaster" emblems in 47, and 48. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | My truck has a 216 so I have a Thriftmaster. Dad had a 52 also I remember it having a Loadmaster emblem on the hood but he sold it before he died. Thanks for the info guys.
1950 4400
