Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Hotrod Lincoln, klhansen, crenwelge), 77 guests, and 4 robots.
Topics128,281
Posts1,058,467
Members48,490
#1374181 08/20/2020 8:05 PM
Hello, I am installing an LS engine and a 4L60E transmission in a 1951 3100. I am also upgrading the brake booster since I now have disk brakes all around. The brake booster from Speedway has a 7” diaphragm so I am concerned that I will have a clearance issue with the transmission. Has anybody installed this configuration with success?
I have done this on my 51, 3100. I have a 5.3 LS and a 6L80E transmission. There are no interference issues with the transmission, M/C and booster, although there is not a lot of real estate for the exhaust. The exhaust runs pretty close to the inboard side of the M/C. I’d attach some pictures but I’ve disassembled the truck as it heads to the body shop next month.
My truck has not been driven yet, so I can’t give any feedback on operation.
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
58 3100 Apache Fleetside
Crusing in the Passing Lane
If exhaust runs close to MC, it would be well to put some kind of sheet metal heat shield to keep from cooking the brake fluid.
Ed
