| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#1371 05/22/2004 11:41 AM | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | Well I finally found the casting numbers (thanks to the info on this site!) and now it looks like I have a 1954 first series 235 in my recent 1949 3100 truck. The block is marked casting 3835911 by the fuel pump with F54Z stamped next to the distributor, and the head is casting 3835913. I guess the swap was sone a while ago. Is this better than having the original 216?
Anyway, with the plugs out it spins by hand (a good sign) and I want to put some new motor oil in it before spinning it with the starter.
What's the oil capacity for this engine?
Also - the generator? has a "12 volt" marking on it. Is this system positive ground or negative ground?
Thanks! | | |
#1372 05/22/2004 12:07 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Yes this is a better engine than the original 216 babbit pounder. It holds 5 quarts of oil and it looks like it has been changed to 12v. Good luck hope this helps. | | |
#1373 05/22/2004 12:08 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | | | | | | Joined: Aug 2003 Posts: 37 New Guy | | New Guy Joined: Aug 2003 Posts: 37 | If it has the optional oil filter it would hold an additional quart for a total of 6 quarts. | | |
