4 members (DaveV, baldeagle, 55shaker, jmoore), 79 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#137397 03/10/2007 12:54 AM
I just bought some headers for my 250 from ftyler. Now to install them. I have read somewhere that you should replace the alignment pins that are in the front and back of the head with actual bolts or studs.
Is this necessary to get a good seal?
What is the process and recommended bolt/stud?
Thanks!
Mike Kelley
1966 Chevy C10 SWB - 250 L6/S10 T5
2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
#137398 03/10/2007 1:11 AM
i have heard that too it is logical, you would need to have pressure at both locations since the headers are two pieces instead of 1 long ex manifold. i am using the shortest 3/8 nc manifold grade stud i could find. the longer ones seem to be in the way.
#137399 03/10/2007 1:41 AM
Does the old alignment pin screw out?
Mike Kelley
#137400 03/10/2007 4:36 PM
The pins are just 3/8" bolts turned down. Yes they unscrew, but there is coolant behind them! You need to use thread seal on the new bolts, atleast on one of my heads I did. I would all so use plenty of high heat sealer on the gasket, both sides and tighten the bolts alittle at a time working across the header flange. Joe
