0 members (),
50
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | I just bought some headers for my 250 from ftyler. Now to install them. I have read somewhere that you should replace the alignment pins that are in the front and back of the head with actual bolts or studs.
Is this necessary to get a good seal?
What is the process and recommended bolt/stud?
Thanks!
Mike Kelley 1966 Chevy C10 SWB - 250 L6/S10 T5 2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i have heard that too it is logical, you would need to have pressure at both locations since the headers are two pieces instead of 1 long ex manifold. i am using the shortest 3/8 nc manifold grade stud i could find. the longer ones seem to be in the way. | | | | | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | Does the old alignment pin screw out?
| | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | The pins are just 3/8" bolts turned down. Yes they unscrew, but there is coolant behind them! You need to use thread seal on the new bolts, atleast on one of my heads I did. I would all so use plenty of high heat sealer on the gasket, both sides and tighten the bolts alittle at a time working across the header flange. Joe | | |
