3 members (classicfins, Donf, 1 invisible),
72
0
Mod | | | Forums66 Topics128,108 Posts1,056,568 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Please forgive my ignorance on this, would I be able to swap the diff gear set from a '54 sedan with my '53 3100 or are they two different animals?
Allan
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy magfarm51, bad news, those two differentials are not interchangeable. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Jim Merritt wrote an interesting Tech Tip about swapping 50-54 PG car axle in a 46-54 3100 truck. https://www.stovebolt.com/techtips/torque_tube_swap.htmTrouble is those PG axles from that time are getting pretty scarce. It’s just a thought. EDIT: I just caught my mistake. Jim's Tip is for 1946 and Older. Not for 46 and later. I am sorry for any trouble caused! Thanks.
Professional Novice
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Hy magfarm51, bad news, those two differentials are not interchangeable. 3B, is there anything about the two that will interchange. For instance, can you insert/mount the car differential and torque tube into the 3100 axle housing? If so, will the 3100 axles go into the differential gears? Probably not, that would be too easy. Thanks for any/all responses.
Professional Novice
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Frank50 and guys, I have no personal knowledge of the interchangeability of parts between the two differentials we're discussing here, that would require a lot of research. I do know that those two differentials are not interchangeable | | |
