8 members (Oswald, Bill Hanlon, Hanks custodian, gswbbc, cmayna, Otto Skorzeny, oldsteve, Stovebolt48), 129 guests, and 3 robots.
Topics128,042
Posts1,055,520
Members48,424
#1369383 07/16/2020 9:27 PM
Moderated
Moderated
I own a '59 GMC 100 with the 4.4 inline six engine. I am trying to locate a new fuel pump, which appears to be a Airtex 531, but can't seem to find one available anywhere. Any help or suggestions would be appreciated!
1959 GMC 100
Carburetion specialist
Probably the best source for fuel pumps is "Then & Now Automotive". They are located in the Boston area.
Jon.
The Carburetor Shop
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Try summit racing .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Moderator, Electrical Bay
CarbKing gave you some good advice. My bet is your pump failed because of ethanol-laced gas. What you'll get from "Then and Now" to rebuild it will be ethanol resistant. I'll also bet if you buy a new Airtex pump it has a really good chance of failing for the same reason. Around 2014~2015 Airtex sent all pump mfg to China and Mexico. Good luck!
~ Jon
Then & Now Automotive.
Very Friendly. Pretty fast turn around time too. Give them a call.
I am a customer for Life.
Todd
1950 Chevy 3100
The fuel pump on my 216 has started to leak out the weep hole on the bottom side of the case. The parts store lists a replacement for my truck, but the pump arm that contacts the cam lobe goes down instead of up. Does anyone know if this will still work? Its a Carter M751
Is it possible to rebuild the pump currently in your 216? If you're wanting to continue with a mechanical pump, this might be a better alternative. I can not tell you where the Carter pumps are made for certain, but on other forums people believe they're made in China. And those may not have any resistance to ethanol blended gas. If you'd be interested in changing to an electric pump, I can tell you the one I've used for over 20 years with good luck. It is made in China, but most of them are and this one doesn't mind ethanol in the gas.
~ Jon
Thank you. I was able to find another option. Airtex 429. Where can I get a rebuild kit from?
Then & Now Automotive. Here you go...https://www.thenandnowautomotive.com/auto-parts-store Call them or send email.
Last edited by Gdads51; 02/18/2026 2:59 AM. Reason: update then and now auto web address
~ Jon
An old fellow had converted a very small AD school bus into a camper. He was stopped on the street and was taking his new fuel pump off. He opened it up and found a check valve that had been put in backwards. After flipping the check valve, he drove right off. That was the first I knew that you can dismantle and repair a fuel pump.
