0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | I’m trying to decide what color I should paint my ‘59 235 in my ‘52 3100 and thought I would ask my fellow “Bolters” their opinions. It is now Chevy orange, which I am not really thrilled with, so I was thinking of gray, the original color of the 216. Were all engines in ‘52 gray or were there other colors? I’m Not trying to restore it to perfection but trying to keep it period correct, as much as possible.
What is your opinion?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | Phil, Both 216s and 235s in '52 were painted the same color, the dark-ish gray as discussed in this forum, called blue-gray in the Tech Article at this link: Jim Carter's Tech Article - Engine Paint Colors by Model Year. This article has the best compilation of colors I've seen, although I would be interested to know if others have a additional sources. EDIT: Tim beat me to it - looks like the same or similar list, in a different article. Cheers! FWIW, the '59 235 would not have been Chevy orange from the factory... either gray (trucks) or blue (cars). I would favor the older 216/235 gray, FWIW. If you are after the '52 look, consider a '53 or earlier valve cover, with the two central hold down studs. Easy swap using the earlier-style studs to replace two of the later engine rocker assembly hold-down bolts, as you probably know. Doug
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jim Carter makes reference to the original article written by Jim Henson (a copy of that original article is in my post above). | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | No 235 / 261 should be orange.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | Being that the options for engine color in the 1/2 ton truck in 1952 was blue gray or blue gray, I think I stick with blue gray!
I didn’t realize that there had been such a discussion on the original color gray. I want to thank you all for your input.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | Does the bell housing get painted the engine color or semi gloss black?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Phil,
Look at the engine gray color for Ford at any auto parts store...it is pretty close to one of the "blue gray" shades used by Chevrolet. Just don't tell any ardent Chevy guy as they may become unhinged. Most of the bellhousings I have seen were painted the same color as the engine.
| | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I sure believe I see the remains of black on the bellhousing of my 216. It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Engines got painted after the bell housings and it's dust covers were installed, so they would be engine color... Mike B  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Organbuilder.
Is you truck engine a USA Chevrolet or a Canadian Chevrolet? | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | It's a USA model, grown up in Austin, MN. I keep in touch with the family that owned it since about 1956, I have not heard that it has had the kind of work done to it that would require repainting. There was not a drop of grey paint left on the motor when I got it. But the housing is sitting in the shop now, and it looks like a little black paint here and there. Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I am looking at the same question now and I will be choosing grey for the bell housing. It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
