1 members (Eisenholtz),
59
Mod | | | Forums66 Topics128,022 Posts1,055,377 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2020 Posts: 3 New Guy | | New Guy Joined: Aug 2020 Posts: 3 | I have 1954 Chevy truck that I recently removed engine because of bad mains,and am replacing with used 235 out of a 59 truck, I bought a new front motor mount and have engine in truck but can’t get balancer all the way on as it is hitting motor mount shield,it’s like my pulley is to large.wondering if shield is not on right or I need balancer with smaller pulley | | | | | Joined: Mar 2014 Posts: 4,478 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,478 | It shouldn't be doing that. Is there any way you could send an image of this?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Are you trying to use the balancer for the 54 or the 59? The 59 has a much larger diameter balancer, and it might not work well with the 54 engine mount. You're also going to find that the water pump on the 59 engine sits too low on the 54 radiator to work well, the pump shaft is too long, and the pump must be modified before the fan will clear the radiator. There's an adapter plate made to allow you to use the 54 balancer and water pump on the 59 engine and get everything aligned properly. Make 3 more forum posts so you will have access to the private message feature of this site and send forum member "Pre-68 Dave" a message, He makes and sells the adapter plates. Jerry
