2 members (Cosmo, Wayne67vert), 43 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
If you have done the 3:55 rear differential conversion, where did you buy yours from? Excluding Patrick's as they are not around anymore, recommend a vendor? Did you also purchase the installation/assembly kit i have seen some of the vendors offer? Other than the gearing and associated seals, bearings, ect. was there anything else you should have/would have/wound up having to purchase to make things easier or more complete of a process. I will be installing it in a 46 1/2 ton pu.
Thanks for your time and input
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
Have searched this forum?
Mother.Trucker (a member here) sells the 3.55 R&P gears.
There have been many posts about doing the installation and buying an installation kit.
vendors that sell 3.55 installation kits
Chris Sweet's Tech Tip on the 3.55 R&P installation.
Ed, Looks like The Filling Station and Jim Carter's Truck are both in a back-order status. Chevs of the 40's has the 3.55:1 Ring Pinion Set, a bit less than the other two vendor's regular prices. I've not used this ring/pinion set from Chevs, but other parts I've sourced through Chev's have been fine, FWIW.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
If you are looking for the Ring & Pinion set, check with Mother.Trucker in a Private Message.
I think that I have only used the Classic Parts installation parts sets, but Chevs of the 40s should have a similar set?
What year is your 1/2 ton truck?
There is a 1930-1940 installation parts set and a 51-54 installation parts set.
ODSS Lawman
ODSS Lawman
Besides the parts you listed, you will need also:
BFH
Dial indicator with stand
torque wrench
pipe
You will need two types of pipe. Listed in my Tech Tip above is a pipe to drive the bearing onto the pinion shaft (1-1.5"?) and a longer one to drive out the okie bushing as shown in the tip.
The most important part of this project is attention to detail. Read the install instructions, and the TechTip ask questions.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
TC it’s a 46 1/2 ton. Will be running a 261 and probably a year correct 4 speed trans.
Appreciate everyone’s time and input. Getting ready to read all the tech tips prior to purchase.
Maybe SWEET or MT or another member will confirm that MT's (or other vendors') 3.55 gear set will work with your year?
I think an installation set for your year is listed in a post above?
