0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | If you have done the 3:55 rear differential conversion, where did you buy yours from? Excluding Patrick's as they are not around anymore, recommend a vendor? Did you also purchase the installation/assembly kit i have seen some of the vendors offer? Other than the gearing and associated seals, bearings, ect. was there anything else you should have/would have/wound up having to purchase to make things easier or more complete of a process. I will be installing it in a 46 1/2 ton pu.
Thanks for your time and input
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | Ed, Looks like The Filling Station and Jim Carter's Truck are both in a back-order status. Chevs of the 40's has the 3.55:1 Ring Pinion Set, a bit less than the other two vendor's regular prices. I've not used this ring/pinion set from Chevs, but other parts I've sourced through Chev's have been fine, FWIW. Doug | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Besides the parts you listed, you will need also:
BFH Dial indicator with stand torque wrench pipe
You will need two types of pipe. Listed in my Tech Tip above is a pipe to drive the bearing onto the pinion shaft (1-1.5"?) and a longer one to drive out the okie bushing as shown in the tip.
The most important part of this project is attention to detail. Read the install instructions, and the TechTip ask questions.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | TC it’s a 46 1/2 ton. Will be running a 261 and probably a year correct 4 speed trans.
Appreciate everyone’s time and input. Getting ready to read all the tech tips prior to purchase.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Maybe SWEET or MT or another member will confirm that MT's (or other vendors') 3.55 gear set will work with your year?
I think an installation set for your year is listed in a post above? | | |
