5 members (GMCJammer51, Phak1, Greg_H, WICruiser, tclederman), 93 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#1371474 07/31/2020 1:16 PM
Hallo,
How must i turn the key to Start the engine? To the right or to the left?
Aak
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
Hello Wolfgang,
If the car you are working on is a Chevy, normally, you turn the key to the right. Usually the first click is a click to activate the ignition coil, then a momentary click further to the right "starts" the car.
A turn to the left, rather than right, initiates the "Accessory" feature (if the car has one).
Good Luck,
pan3lman
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Early Chevrolet three position switches were “on” in the center. Lock to the left, and off to the right.
What are you working on?
My Blog
Wolfgang, please go to your profile information and put your vehicle specifications in your signature line. By doing that we won’t have to ask you every time what are you working on. Things vary from the 1920s thru the 1970s. Help us help you.🛠
Wolfgang,
Truck ignition switch - with 2 positions....
to the right is on,
to the left is off.
-Tom
1950 Chevy 3100 w/ 1956 235
Wolfgang,
Do you have a foot starter?
Craig
Fox Offline
Is that right from the top or bottom?
Turn clockwise to turn on.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
wokri #1373187 08/13/2020 12:22 PM
Crusing in the Passing Lane
Do clocks turn backward in the Southern Hemisphere?
Ed
I assume your '53 is the same as my '48. Like Pre-68 Dave said, key straight up and down is "On." To the left (key turned counterclockwise) is "Off" and locked when the key is removed.
To the right (key turned clockwise) is also "Off" but the switch can be turned back on without the key. This position could be for the farmers who did know who would be driving the truck next.
