3 members (Ponchogl, dt235sd, mason86), 113 guests, and 2 robots.
Topics128,047
Posts1,055,662
#1372055 08/04/2020 4:00 PM
Just brought this 49 3600 home. No real plans for it other than fixing what needs done and modernizing as necessary.
Pat
1940’s tech was great in the 40’s
AwDang #1372081 08/04/2020 7:31 PM
Aw Dang it, welcome to Stovebolt. you join many others from Va. so watch for them. Nice looking pickup for sure. Thanks for the picture.
AwDang #1372085 08/04/2020 7:56 PM
Welcome to the Stovebolt madness. There is no cure! shake
AwDang #1372086 08/04/2020 8:00 PM
Looks to be in good shape and already being put to work. thumbs_up
AwDang #1372092 08/04/2020 8:54 PM
Former Workshop Owner
Great find. thumbs_up Welcome to the Stovebolt.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
AwDang #1372099 08/04/2020 9:15 PM
Thanks guys!
I tried to drive it the 1000mi home. Unfortunatly it ate the front tires in 200mi and ended up on a trailer.
Pat
AwDang #1372105 08/04/2020 9:37 PM
Looks good from downunder as well you will enjoy keeping the dream alive
AwDang #1372109 08/04/2020 10:03 PM
Congrats, that is a nice looking truck! Welcome to StoveBolt.
1951 Chevrolet 3100
AwDang #1372123 08/05/2020 12:05 AM
nice looking truck, have fun with it before you tear it apart.
Another quality post.
Real Trucks Rattle
AwDang #1372165 08/05/2020 5:12 AM
Fox Offline
Don’t do that now! Drive it! Everyone is very good at taking these old girls apart. Not everyone has the ability, patience, time, money, and an understanding significant other to put them back together. 😉
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1372170 08/05/2020 10:54 AM
It’s driveable......for about 150mi at a shot. Then it needs a tank of fuel, a half gallon of water, 3 quarts of oil and 2 front tires.
Pat
AwDang #1372172 08/05/2020 11:29 AM
AwDang!
Nice truck.
Get new tires.
Check for oil leaks. (if you need gaskets, replace them).
Check for water leaks. See what need to be repaired/replaced.
Tune the engine.
Then, report back.
Unless you are bound and determine to "modernize", get it running like it was made to run.
Good luck with you truck and good luck with you efforts/strategies.
AwDang #1372175 08/05/2020 12:38 PM
I’m using modernize very loosely. It needs to get legal and reliable. So, 12v, Pertronics/hei, electric wipers, new rear end with better gearing, disc brakes and dual circuit.....that type of modern. I’m not heading down the S10 swap road. I want to keep this as a 3/4T truck to do truck things with. Maybe sometime down the road add 4wd to it with a little lift.
Pat
AwDang #1372184 08/05/2020 1:55 PM
AweDang, you should consider making the trip to Clearbrook Va for the TriState truck show. You would be hard pressed to find a better example of AD trucks such as yours,along with a very knowledgeable,friendly group. You can find details in the ODSS forum. Pat66. https://www.stovebolt.com/ubbthread...ad/Number/11664/filename/20190928_164217[1].jpg
Pat66 #1372185 08/05/2020 2:21 PM
Thanks! I’ll check it out.
I’m not sure I’ll have her up to a 600mi round trip that soon.
Pat
AwDang #1372201 08/05/2020 6:36 PM
Crusty Old Sarge
Crusty Old Sarge
Nice Truck, I would get it running , stopping and driving and then start making plans for upgrades. A lot of things change once you start working on it.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
