3 members (tclederman, 2 invisible), 51 guests, and 5 robots.
Topics128,021
Posts1,055,372
Members48,420
#1371620 08/01/2020 2:42 PM
Can you use the mechanical mechanism from a stomp starter set up on newer 6 cylinder engines like a 292 engine or other engines from the late 60's? Just wondering if those parts/transmissions from ad trucks interchange with newer engines ?
1950 Chevy 3100
In the DITY Gallery
77 International Scout ll
96 F-150 ext cab 4x4
2000 Tahoe
2011 chevy 3/4 ton 4x4
Moderator, Electrical Bay
The 292 must have a different bell housing and I think the starter drive/flywheel tooth count are different also. Nearly anything could be done, but as to interchangeability I'd say no.
~ Jon
You can fake a foot start by using a starter switch for a tractor and adapting the stovebolt start pedal and rubber boot to it. Just use the foot switch to energize the later model solenoid switch or a magnetic relay. Unless somebody looks under the hood they won't know the difference.
Nice information, Jerry
Can you post a link to the switch.
My guess is that there are a lot of different “tractor” switches?
Sir Searchalot
Sir Searchalot
I think we have a post or two regarding that. With pics. I remember discussing the design somewhere. Will try to remember. (That is a difficult task now a days.)
But I know I've seen it. I even drew something up, don't know if I posted it or not. I think Jerry was in on it too.
Sir Searchalot
Sir Searchalot
Here
3100Cummins links to 67-72 site.
He also shows pics in that same post.
Also Grigg links to another post, then:
See the Jim Sears Photobucket pics
Another post
I'll stick to the mechanical linkage and correct years of adaptable parts. Thank you all for your input on this.
Jim
1950 Chevy 3100
In the DITY Gallery
2000 Tahoe
