1 members (Jimmie D),
110
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | I just purchased a 1969 Chevrolet C10 step side and was told the engine was a 235. When I got the truck the Distributor is toward the front of the engine not in the middle. I suspect this is a 230 engine. I have the casting number as 3921968 and the number just behind the Distributor is F0602PP. Can anyone help me confirm the engine type> The VIN number is CS149 J 864449 if that helps. Thanks Pete
Chevy Pete
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The only difference in a 230 and a 250 engine is the length of the stroke- - - -they use the same block casting and the bore size is 3 7/8" on both engines.. If you can get a borescope into one of the spark plug holes, look at the top of the piston. The 230 has a flat top piston, and the 250 has about a 1/4" deep dish in the piston crown. You might even be able to check the piston with a long, narrow screwdriver blade with the piston near the top of its stroke. Jerry
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Here's your VIN number CS149 J 864449 break down... C = Conventional Cab S = 6-cylinder engine 1 = GVW range (3900-5800) 4 = Model (Pickup) 9 = Year (1969) J = Janesville Assembly Plant 864449 = unit number starting with 100001, so you have the 764,449th unit built for the 1969 model year from the Janesville Plant. The smallest 6-cylinder available in a C-10 in 1969 was the 250. Mike B  | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | Thanks Mike and Joe. My fuel pump is closer to the distributor but my distributor looks more like the 292 picture. Are they interchangeable?? I couldn't get my bore scope to work today but will keep trying.
Chevy Pete
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Look at the motor mounts. The 292 is the only engine with them offset side to side. The 194, 230, and 250 have mounts directly across from each other, and the same distance from the bellhousing as a V8. The passenger's side mount on a 292 is about 3 inches further forward than the driver's side mount. The HEI distributor with the large diaqmeter housing and cap will fit the earliuer engines with point-type distributors. Jerry
