Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (78buckshot), 43 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1371645 08/01/2020 5:44 PM
New member to group. Need some engine id help. This 235 is in my 53 5 window that we recently purchased. Distribuator numes are-0592656F54X
Numbers on head are 3836848 and at the starting motor 001n D144. Thank you for your help!
wilbur53 #1371701 08/01/2020 10:33 PM
That is a '54 235, originally used in truck service (so will be a full pressure, solid lifter engine), manufactured in Flint, MI. Casting date decodes to April 14, 1954. The head is a bit later vintage. That '848 casting was used '56-'62, and is considered by some to be desirable, since it has the smallest combustion chamber size, good for about a half point of higher compression in stock form. There is a date code on the head, but the valve cover has to be off to see it - just a bit farther back from the casting number, on the driver's side (and under the valve cover).
Just so you know, the '54 blocks that were originally fitted with solid lifters don't have the oil gallery drilled to support hydraulic lifters. Solid lifters only at rebuild time, unless someone ambitious, with $$$$ and a good machine shop, modified. Unlikely, that.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
drdoug #1371703 08/01/2020 10:44 PM
Doug,
Thank for info. This clears up some question that i had.
Dave
