1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
My 1950 4100 fire truck has been on lock-down for an extra 5 months this year in a warehouse. It was running when I parked it in September, but this week I went to get it out of there, but, it was crank, crank, crank, don't burn the starter up. Trip home for tools, and no flash from my timing light while cranking. Focused on the near new Bluepoint points, and nothing was making sense. Changed points, and it fired right up. Long story short the pivot on the points was seizing up, which wouldn't allow the points to tightly close. Weird, and then I had to deal with my clutch disc stuck to the flywheel. Need to drive it more I guess.
Even Fire Departments start the seldom used trucks every 3-4 days and let them come up to temperature. Bring it south 500 miles and I’ll drive it for you. Just to keep the fluid flowing. drive
Crusing in the Passing Lane
Fire trucks are frequently always hot, electrically anyway, so be careful when working on one.
Ed
