4 members (Peggy M, Otto Skorzeny, klhansen, farmallb), 107 guests, and 2 robots.
Topics128,041
Posts1,055,487
Members48,424
#144856 11/17/2005 4:10 AM
Junior Member
Junior Member
Hi, guys:
Newbie here. Recently acquired a 53 Chevy 6100 Ashton Wrecker. Am curious if there are power steering conversions available for this rig? Or if not, is there any other (newer) year truck or vehicle that may be a bolt on replacement? Don't laugh but I am not strong enough to drive this puppy in current standing. Am just a girl.
K. Wells
57Heaven
PS... Why the big rig? She was just too cute to pass up.
#144857 11/17/2005 5:14 AM
Girls are welcome here too. We had a bit of a fight one day when I brought home another truck and the two girls in my life both said it was cute and wanted it for their own.
The wife won, the daughter will have to find her own truck...
Scott Ward converted a big truck to power steering he should jump in here soon with some information about what he did. I don't think you'll find a kit, but that doesn't mean it can't be done.
#144858 11/17/2005 5:33 AM
3B Offline
There are no kits to convert that I am aware of, but a system could be made up using newer components, if you can't do the work yourself it will be expensive. All you really want to do is lessen the steering effort, believe it or not I have heard of people adapting ram assist steering from a fairly new corvette, I'm not sure what year I'm a truck guy not a sports car guy good luck.
#144859 11/17/2005 5:48 AM
Got any pictures !
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#144860 11/17/2005 7:38 PM
What I did (right or wrong) is, I put a 78 3/4 ton 4x4 steering sector in from of the axle on the side of the frame and made an adjustable shaft to hook up to the steering linkage. I then swapped out the steering column for a later model GM (I think it came from a 76 Monte Carlo) and fabbed up a shaft to go between the column and the sector. The main reason that I did this conversion was to get a V-8 in there, the P/S steering ended up being a welcome bonus. With the powr brakes, steering and the V-8, this is a nice truck to drive, even my wife has driven it. She has no interest in driving the stock one, other than to maybe to use the dump bed on it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
#144861 11/18/2005 9:55 PM
Scott if you can get your wife to drive any of your trucks you're doing much better than I!
My wife won't even drive the half-ton with automatic, power steering and brakes...
Wait a minute, maybe that's not a problem. That means its always parked outside when I want it!
#144862 11/19/2005 4:28 PM
Riding in the Passing Lane
My wife won,t even ride in mine.
1972 Chevy c10 Cheyenne Super
#144863 11/19/2005 5:30 PM
Steve,
The wife only drives it when pursuaded to, otherwise she doesn't really care. I like to keep her "into" my hobby so I can enjoy spending time with her doing what I like to do. Later on this winter/spring I'm gonna do a quicky build up of a ratrod 50 pick-up for her to drive. That way she can join in on some of the old truck "fellowship" at cruise -ins and local shows. I've been aquiring parts all summer and after I make my restoration project self propelled again and do up BradB's frame and suspension for his panel, I'm gonna get started on it. She's a good sport, she goes to all of the shows and swapmeets even when it's way out of town. She has a love for a 70 Chevelle SS bigblock car but it's a little out of our price range right now, so I'm hopin' the 50 satisfies he needs for a while,
Scott
P.S sorry about hijacking your thread but you DO have two of them (LOL)
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#144864 11/20/2005 2:39 AM
steering sector??? is that another way to say steering gear box??? if so I had a similar idea for my 51 6400
#144865 11/20/2005 6:10 AM
Quote
Yes,
Since it doesn't really have gears but a recirculating ball configuration I thought "sector" would be more fitting. Sorry about the confusion,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
1 Offline
Hello,
Sorry to start up to an old thread,
with using the 3/4 tonne steering box, how did it hold up on the larger 1.5/2 ton truck.
Was it very heavy or did it break under the heavier load and bigger tyres?
Cheers
Mathew
1958 Viking 4400
day late and a dollar short, but i did see something about stealing the p/s box out of a chevy p30. if i can re-find that thread ill happily come back to share the link.
Trying to do a p/s setup on my 2 ton 54 GMC 350. because of a v8 swap i have to move the box, spline the steering shaft on both ends where i cut a section out of the middle. Splined HD U joints and a HD steering shaft that will connect the two. the angle wouldn't be severe as i believe the box only has to move an inch, so it should be smooth steering without sacrificing strength. others may think differently but im gonna go for it worst case scenario is it doesn't work and im back at square 1. good luck!
THE BLACK VIKING
1958 Viking 60 ~ my new toy hauler
My Current fleet: 1954 chevy 3800, 1953/4 gmc 450 coleman 4x4, 1956 chevy pickup, 1958 Viking 60
Keep 'em rollin fellas!
The ram assist power steering was used on Chevy cars up through 1964, Mustangs through 71, Corvettes to about 1990, and many 4wd and construction equipment. It works very well but on lower vehicles the hoses were hard to keep keep up out of the way of snags. On a big truck it should work fine. To install you mount the control valve on the pitman arm end of the drag link, make mount brackets for the ram on the frame rail and the tie rod, mount p/s pump on engine and run the pressure and return hoses. Not a complex install at all and changed none of the original design or parts. Pics of the set up on a 1940 International with straight axle.
Control valve on drag link:
[img]https://i.postimg.cc/xk7RB1Hm/straight-axle-p-s-003.jpg[/img]
Ram mount in tie rod (other end of ram goes to bracket on frame):
[img]https://i.postimg.cc/JtB1fYwH/straight-axle-p-s-002.jpg[/img]
Ram end in tie rod:
[img]https://i.postimg.cc/HrjHt6tL/straight-axle-p-s-005.jpg[/img]
I have a Prius electric power steering unit that I have not used on anything yet and have no idea what type of load it can handle but if it can just give like X pounds of assist and not burn up then it will do away with pumps, hoses, valves, etc. This would change NOTHING of the front end parts.
Evan
Crusing in the Passing Lane
It is good to stagger ends on braces so all the stress does not terminate at the same location.
Ed
It's not bolt-on, but pretty close- - - -try a power steering box from a Toyota Land Cruiser. There will be some adapting required where it mounts to the frame, and you'll need to fit a steering pump to the engine, but it's probably simpler than using a boost cylinder from the frame to the tie rod and a sensing valve grafted into the drag link. The 82 Corvette with 9500 original miles that I inspected a couple of weeks ago had the boost cylinder steering setup, but the sensing valve was built into the Pitman arm at the steering gear.
Hey Old sub my experience since about 1966 has been ...best to buy 'em that you'll be able to sleep in for awhile LOL.
