4 members (Peggy M, Gib70, Gray_Ghost, 1 invisible), 252 guests, and 2 robots.
Topics128,089
Posts1,056,117
Members48,434
#137137 02/10/2007 2:14 PM
ok, i've got my 50 jimmy on ebay so i can procede with the 62 chevy i've got and i'm looking for ideas for a front suspension for it.
1st off, a MII is out of the question (not HD enough)+ they're not wide enough.i tend to use a truck as a truck;)
i don't think a 63-87 PU swap will get it as low as i'd like.i don't want to use dropped spindles either...
yeah, i COULD do a camaro swap but that's been done to death BUT i do have a couple laying around..
got any FRESH ideas?
i miss obscene phone calls...
#137138 02/10/2007 5:21 PM
Stock torsion bars cranked way down, in addition to 2-inch dropped spindles. And then section the cross member for the additional ground clearance.
It'll ride pretty comfortable.
I know the big pain with the T-bar front is the horrible expense of rebuilding the ball joints, etc. There's a dude on Ebay selling new lower ball joints for $89 a pair, which is a huge savings compared to the $150 EACH I've found everywhere else.
Once you get done figuring in the cost of all the fab work and rebuilding the replacement parts anyway, I don't think it's that much of a savings over rebuilding stock front. Add a disc brake kit and power steering with a quicker ratio box, and I don't see a reason not to run the original front end.
Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
#137139 02/10/2007 9:48 PM
what are you trying to accomplish?
1949 SUBURBAN
#137140 02/10/2007 11:14 PM
something different besides the MII/camaro sub/pacer stuff.
thinking vette or jag at the moment...
#137141 02/11/2007 2:43 AM
Somewhere I've seen pictures of one done using C4 Corvette stuff. Go with C5 stuff and that would be new to at least me. Better yet C6 Z06 stuff with that new 427...
Jag is different but doesn't really gain much so I'd have trouble thinking it worth the work.
#137142 02/11/2007 3:32 AM
I plan on using a 'vette front end when I get around to it. Next winter maybe. I can find them for around $800.00 in really good shape here in the south-east. If I went MII from "Fat Mans' over in North Carolina it would set me back 2 grand plus. Besides, like you I've seen enough MII's and Camero's. A buddy who is going to help me install the unit has one sitting under a '48 International panel truck with a 350 chevy motor so they gotta be heavy enough.
#137143 02/14/2007 2:19 AM
1 Offline
Tomslik
I was going to install a 1987 C10 IFS on my 51 but the tracking was to wide and without taking about 1 7/8" out of the center of the saddle I was going to have to put 1" spacers between it and the frame. But I was told from several people that it fit good on a 58 thru 66 ?? and with drilling a couple extra holes on the frame it was almost a bolt on ?? its heavy duty enough for just about any engine setup you go with, look into it and see Im not sure but thats what I was told
good luck
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
#137144 02/14/2007 11:56 AM
yeah, they'll fit but like i said, it'd just be a stock height truck then....
dropped spindles are out of the question, if i'm gonna go to THAT much trouble, it better be low...
thing is guys, i'm looking for the unusual, that's why the subframe/MII comment.
#137145 02/14/2007 6:58 PM
1 Offline
OK....
Use a honda goldwing front forks and that will bring it down to the ground and sparking
and talk about unusual...
if you "tend to use it as a truck" then keep it as a truck, a vette or jag the last time i checked is a CAR
#137146 02/14/2007 8:42 PM
Junior Member
Junior Member
I am going with the c4 suspension and got the crossmember from Flat Out Engineering. There are no complaints from me on the design or the strength, being made of 2x4. In the front it should work just as good as your truck seeing as corvettes had the weight of the v8's and 11 in rotors for 84-87 and 12 in on 88-96. Plus you will get rack and pinion steering.
#137147 02/14/2007 8:45 PM
Junior Member
Junior Member
A link to the picture of the crossmember.
http://i18.photobucket.com/albums/b114/cbarle1/DSCF2766.jpg
