Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Gdads51, MTD91, Forty9), 117 guests, and 2 robots.
Topics128,278
Posts1,058,573
Members48,492
#1371219 07/29/2020 11:25 PM
Hello fellow enthusiasts!
I'm trying to acquire a little info on this truck. This beauty is my girlfriends (lucky me). It's pretty much bone stock mechanically, 6V, 3 on the tree, floor start.
I'm trying to determine the motor, I'm pretty sure the Canadian spec GMC had a Chevy motor, but of that I'm not sure.
I have attached a couple of pics, one is the serial number on the block, the ID plate on the door and a pic of the old girl herself
I did search for the motor info, but came up short
Phil
Hello, Phil,
Welcome to Stovebolt.com.
There are many Canadian members here. They will know the differences/nuances of Canadian GMC & Chevrolet Trucks.
If you engine has ID markings in the same locations as USA Chevrolet trucks, find and post the codes in these locations.
Your Engine Serial Number is: 287861 3946
Someone will decode this and post the information.
I'll crop and rotate your ID photos, and then attach/add them to this post.
Go to the site oldgmc.com they have a little on Canadian serial numbers .I beleave the truck is a 1955 first series the first number is the year then the next is 1 for chev 9 is for gmc ,3 is the series 9300,1 ,is the wheel base (116) and 4 is for pickup.the rest of the numbers is the truck number
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Does the truck have a torque tube or a driveshaft .The 55 was the first year.for the driveshaft .The Canadian trucks came with a 235 engine .By the way nice truck and welcome .I don’t know about the engine number as mine was a rebuild I would think the number on the plate should match the engine .You could post the casting numbers to see if they match the year of the truck
"The Journey"
Follow in the DITY
Thanks for the warm welcome!
Hi @KEVINSKI, she has a torque tube
Thanks for the welcome tclederman, and for cleaning up the photos, verifying the s/n on the block
Phil,
That is a beautiful truck.
Both of my 1954 gmcs have open drivelines. But they would be US models w/248 engines.
Curious what you discover.
Mike
AS i understand it.. Chevy and Gmc still used torque tube in 54 and 55 1st in Canada.
1954 GMC 9314 - 261 t5
Thank you, canuck49
You saved me from having to search for my 1954 GM Canada Trucks Maintenance Manual.
(cover image is attached)
I have never seen a early or late 1955 GM Canada Trucks Maintenance Manual.
Supposedly, there was a late-1955/1956 GM Canada Trucks Maintenance Manual.
Insomniac
Insomniac
We have travelled through Falkland many times as I have a Brother in Kamloops and a sister in Vernon. We always stop at the little Western themed restaurant to pick up some tasty pies.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
A maintenance manual would be fantastic, though I have managed to download pages I need
Gord&Fran, The Ranch cafe, it’s under new management and now have a smoker for bbq, to soon to tell if it’s a good thing
Way back most of us tried to get our hands on Canadian built 265, 283's because they had thicker blocks. I ran C/Mp (C modified production), it was punched max. That was in the days when we could cheat a little. Were the six cylinder's from Canada thicker? By the way Stagerguy that is a beautiful truck, you win, the girl and the truck! Welcome to the greatest site anywhere. Doc.
I agree! It’s a beautiful 55-1st Series GMC Half Ton. Congrats!!
The chart below covers 47-54 but the model number scheme still applies to 55.
https://www.stovebolt.com/ubbthread...-54%20Canadian%20GM%20truck%20series.png
Professional Novice
Thanks Doc.Hall
Thanks Frank50, pretty simple VIN de-coder smile
2 Offline
You are welcome smile
Fox Offline
Did you find it?
Check your casting code. It should be on the right side of the block in front of the distributor. It will be raised. This will tell you if it’s a 216 or 235, as Kevinski said. I’d be surprised a truck like that has its original engine still. It simply isn’t crusty enough! Nice truck. Yes, CDN GMCs used Chev engines on the little trucks so we Canucks don’t have to worry as much about the dreaded frame differences our southern brothers do.
By the way, whatever happened to those links that were at the top of the Engine forum and had a bunch of those decoders listed?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Here is a pic, I'm pretty sure this is the casting number. This number is stamped in front of the fuel pump, there are no numbers in front of the distributor (nothing between dizzy and fuel pump)
2 Offline
searching the web seems to indicate this engine block is most likely a Canadian produced 1954 235, but there isn't much to go on.
if you take it apart plz let us know for certain
thanks
-s
