2 members (Ponchogl, Leo), 67 guests, and 2 robots.
Topics128,127
Posts1,056,681
Members48,452
Hi Guys, I'm just going through a rewire on my 53 1/2 ton I bought and I see I don't have a neutral safety switch. I have a 350 turbo trans. Dose anybody have a simple solution?
Don
The neutral safety and backup light switch is usually on the shifter. Check with the Genie shifter folks to see what they offer.
The hot rod guys that run steering columns without a neutral switch or floor shifters fab one up under the car where the shifter arm goes to the tranny. a simple n/c switch with a rubber booth works great. Fab it so you can get a little adjustment so it will work as you would like it to. You can't pass the safety inspection for the National Street Rod Assoc. without one.
I think Lokar might make one that will work. Have a look at their catalouge
1940 Chevy KC 1/2-Ton
I just installed a Lokar neutral safety switch this past week. It was a neutral safety switch and backup light relay setup. We didn't use the backup relay though. Their instructions were bad though,had to call them twice for more info. on the installation. If you get a lokar give me an email and I will direct you thru the hookup.
