| | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 102 | I have the check-link, as shown in the attached pic, I just need the anchor that bolts to the door; mine was rusted apart.
Anyone know if these are available?
Thanks!
1963 C20, 292 (4.8L). 4-speed.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Pricey You can make an exact copy pretty easily. Do you have a welder? Are you mechanically inclined? HERE is one here in AZ, near me.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2020 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 102 | Pricey You can make an exact copy pretty easily. Do you have a welder? Are you mechanically inclined? HERE is one here in AZ, near me. Thanks - that helps! I probably could make one.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I wouldn't hesitate to buy one for $7.50. I would hit the "buy now" on that ASAP.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | You might like the Jeep door check upgrade unless you are trying to stay original. Here’s a DIY I wrote. I have them on my 1965 C10. Jeep Cherokee Door Check DIY | | | | | Joined: Apr 2020 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 102 | I wouldn't hesitate to buy one for $7.50. I would hit the "buy now" on that ASAP. Oh Yeah - I ordered it! $7.50 is cheap! And the shipping was only $3.50.
