1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
Hi All,
I've been making progress on cleanup, and I had a question about the leaf springs. I've included pics of the "worst looking" one. Can these be cleaned up and reused, or would I be better off getting replacements? This truck was apparently buried up to the bottom of the cab when I bought it. As much as I love spending money on my baby, I'd like to reuse as much as I can. grin
Thanks for any help y'all can provide.
Bret
1952 Chevy 3100 - currently apart and hogging up the garage.
You could probably clean and reuse those springs.
Wait to hear from other members.
Here are some videos and articles/reading-material.
I would buy new springs.
That’s some serious rust issues right there!🛠
Thanks for the link! Watching how much goes into rebuilding these now. Helps me make up my mind. smile
Yeah it really is. That's why I was trying to figure out if these were even savable. I did some wire wheeling on the front springs, and they are cleaner, but still a bit pitted. Not sure if pitting (the light kind) plays a factor in leaf springs.
Crusing in the Passing Lane
Not supposed to sandblast spring leaves. Several on here have gotten new springs and been very happy, some shop near St. Louis. Look back through recent posts. I would replace them, not worth the labor, broken leaves.
Ed
Ed
Ah I see. I don't have any sandblasting equipment (yet), so my plan was just to wire wheel them. If it's too much of a hassle, it might be worth the few hundred versus all that sweat.
Moderator, Electrical Bay
Just my 2 cents, but I believe these springs are never going to work as smoothly as they ought to again. There are a few different spring companies in Houston...Draco, C & J and you might also check with Pruitt. I'm certain you'll find somebody who can make a new set for you. One word about springs and buying from somewhere far away: These are heavy, they're oversize and usually they require special packing/boxing. I think you'll pay about $30~$40 in shipping for each spring. That's why I'm suggesting a drive into Houston. Good luck.
~ Jon
PS...also (very important postscript) get new U bolts made and new nuts for them. Please forget using the old ones. These as you already know are not really U bolts but U bolts with flat tops. If you can't find anyone down your way, send your old ones to Truett Worrall Company up here and they'll make new ones for you. https://www.twsprings.com/
~ Jon
Thanks Jon for the tip! I was leaning towards replacement, based on everyone here’s input, and that’s a good point. I’m not sure that they would be the same even after I cleaned them up. I’ll for sure check out shops around town here, for both the springs and the U bolts.
Good luck Bret. Please be certain when you're talking to them to remember that you'll need new spring eye bushings with the springs. It is a snap for them to install those when the springs are being made and new eye bushings and shackle pins make a real nice difference in things. You might also see if they'll throw in the eye bolts and if they will be certain to get the ones with grease zerks. Usually they will do that (for a charge of course) and it is usually less expensive because you often have to buy those as a set (with the bushing) and then you have to pay for an extra bushing...if that makes sense. Hope it does.
~ Jon
Former BMW Rider
Former BMW Rider
I vote for a total replacement of your leaf springs. I just recycled these front and rear leaf springs from my '47 3104. Note how the shorter leaf has worn into the longer leaf. I purchased new springs (front and rear) from St. Louis Spring for just under $620.00. They came with new bushings too. What a total difference in the ride.....
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Oh wow! Yeah I think that new springs are in order. I haven't been able to get mine off yet and fully cleaned to survey whats under the dirt/rust, but I have a feeling that it won't be good. I guess my blasting cabinet will have to wait another paycheck wink
I replaced all mine with new springs from St. Lois Spring for the same reason as HandyAndy - the shorter leaves had worn into the longer leaves. I also got the u-bolts and nuts from them. The springs came with new bushings installed. I got the fronts one summer when visiting my folks near St.Louis and the rears the next summer. I called them with the order in the morning and picked them up that afternoon. Very good service and quality!
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Another vote for St. Louis Springs. I have had a lot of old trucks and my 52 is the first one I did all new springs on. I never knew these trucks could ride so well.
They ride nicely with new springs and if you radius the ends of the leaves where they mate with other leaves just slightly and install lipped liners they ride even better (and more quietly). Radiusing the leaves is a very old trick and I'll tell you another in a moment. These are simple springs and any decent spring shop will be able to make them. Making them work at their best is up to you. When I was in high school we would save a quart or so of old crankcase oil, mix that with equal measure of kerosene, jack the car/truck up and apply that to the springs with a hand pump oil can. It wasn't a lot of fun (particularly in the winter), but your vehicle would ride like new for a few weeks. When it was time to do this again (next oil change) we'd go to the coin op car wash and hose the dirt/dust off the springs first.
Bret it dawned on me last night that one possible rescue for your old springs might be to use spring liners. If the inner parts of the springs are not too pitted, liners might get you by. Spring liners can be Teflon, HDPE, LDPE or other poly compounds. I like the lipped ones because they stay put. Here is an example of the width you need: https://tinyurl.com/y4ur8oro Just a thought.
~ Jon
Samantha
I’ll check them out for sure! I haven’t had a chance to check out the local shops yet in person, but if it’s still cheaper with St. Louis Springs, I’ll be giving them a call.
Thanks Jon! I’m planning on getting those springs out sometime this week. I’ll take a look at the insides and see if I can get by for a while with liners. I’ve been pleasantly surprised so far with how the chassis looks after cleanup, so I’ll post an update with what I find out.
