6 members (DadsFirstPickup, Otto Skorzeny, Hotrod Lincoln, Dennys28, DES57, 1 invisible), 45 guests, and 3 robots.
Topics128,035
Posts1,055,447
Members48,422
#1367356 07/01/2020 8:40 PM
rad
Offline
Looking to put new rims on my 49. It has an 1970 ish rear end, the hub size is 3" the rims are 72.6 mm or 2.85 inches. considering turning hub on the lathe. has anyone experienced this or have a better solution. don't really want to hog out the rims. thanks
rad #1367372 07/01/2020 10:56 PM
I don't know much about it but I'm impressed you said lathe and not grinder.
rad #1367376 07/01/2020 11:04 PM
Crusing in the Passing Lane
Have to pull the axle to turn down end, look for proper rims, or turn the wheels on a lathe.
Ed
rad #1367424 07/02/2020 5:14 AM
A suggestion; it is very easy to turn one down on a lathe but LEAVE THE THICKNESS of the brake drum the original size on the axle pilot (hub). You really don't need a "floating" brake drum that is only positioned by often not too tight fitting (to the brake drum) wheel lug bolts.
Evan
rad #1367449 07/02/2020 2:22 PM
Insomniac
Insomniac
ISTM that the best solution would be to identify the rear end. Once you what the donor was, buy wheels that fit.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
