2 members (carbking , TUTS 59 ),
108
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,029
Posts1,055,416
Members48,422
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Looking to put new rims on my 49. It has an 1970 ish rear end, the hub size is 3" the rims are 72.6 mm or 2.85 inches. considering turning hub on the lathe. has anyone experienced this or have a better solution. don't really want to hog out the rims. thanks
I don't know much about it but I'm impressed you said lathe and not grinder.
Crusing in the Passing Lane
Have to pull the axle to turn down end, look for proper rims, or turn the wheels on a lathe. Ed
A suggestion; it is very easy to turn one down on a lathe but LEAVE THE THICKNESS of the brake drum the original size on the axle pilot (hub). You really don't need a "floating" brake drum that is only positioned by often not too tight fitting (to the brake drum) wheel lug bolts.
Evan
Insomniac
Insomniac
ISTM that the best solution would be to identify the rear end. Once you what the donor was, buy wheels that fit.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed
