0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#136730 01/12/2007 4:59 AM
Hello again,
I'm looking to put my 49 2-ton AD truck on a 4x4 frame. I thought there might be some benefit to the larger fenders, as I could put bigger wheels on without having to lift the truck so high.
After looking at pictures, though, it's hard to tell any difference in the dimensions of the big-bolt truck front clip compared to the standard pickup front clip,,, other than the larger openings that is.
Can anyone point out the differences between the two? Is the track-width of the big bolt larger than that of the standard pickup? If so, what is it? Is the front clip of the big bolt any longer??
Again, I appreciate the feedback, thanks!
Jon
That's perfect,, exactly what I was looking for.
Thanks!
Jon
I haven't seen it done with a Chevy/GMC, but a few years back there was a trend with guy that had late '60s/early '70s fords to use the 1 1/2 ton and larger fenders on their 4x4s for the tire clearance and to get away from fender flare laws concerning tire coverage.
Bill Burmeister
Glad I'm not the only one with the idea. Thanks.
Jon
Hey Joe,
That last picture looks like a pick-up fender that's been cut up. It may not be a big bolt front clip. To make a big bolt fender look right, I would think the opening will need to be tightened up some (with p/up fenders),
Just my 2 cents worth,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
