3 members (moparguy, 3B, Chip O), 139 guests, and 1 robot.
Topics128,192
Posts1,057,350
Members48,469
1 Offline
I have a tilt steering column and master cylinder booster & pedel assambly form a 1987 C10 and I want to install it im my 1951 3100 along with a Mustang II kit has anyone ever done this and how did it turn out & how do you like it ?
Waiting for my kit to get here "any day' I hope ! and looking for some ideas
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Junior Member
Junior Member
I used the pedal assy, and booster/mc from an '86 C10 in my 48. I used a column from a late '80's van. should be the same as the truck column, only shorter. Keep in mine that I haven't driven my truck yet, but I am happy with the way that it turned out. I was not able to use the factory bracket from the van (wrong angle). I had to by an aftermarket column drop from ididit (about $75), and weld a flat piece of metal across the bracket just below the bottom of the dash. I have a Camaro clip in my truck.
1962 Stepside
1948 GMC
1969 Chevelle
http://mgiles5.photosite.com/
Hot rodders and Street Rodders do this all the time. There any number of articles in the "Hop-up" mags such as "Streetrodder" and "Streetrod Builders". Of course your change over is going to be different, but then they all are unless your truck looks like a '32 Ford. The things to watch and plan for are all there. Such as how the steering wheel should sit in reference to the driver both distance from his gut, if he has one, and the angle the driver feels right with. Also a biggie I have seen is the number of universal joints from the end of the steering shaft to a input shaft on the steering box. I believe more than two universals and a brace is needed. I have put two into street rods and it wasn't a big deal with planning.
1 Offline
Im just now installing the Mustang II kit,and I think the GM column will work, Im going to to have to change the column mount and figure out how to get around the block hugger headers and tie it in on the power steering rack
Todd
