3 members (2-Ton, Hotrod Lincoln, 1 invisible), 86 guests, and 2 robots.
Topics128,165
Posts1,056,988
Members48,458
I recently purchased a running 1962 Grumman Olson kurbside,
Mechanically everything seems fine other than a sticky accelerator pump and leaking master brake cylinder.
I'm sure other issues will pop up but for now I want it to be able to stop before it can go.
As far as I have been able the find is this replacement cylinder:
https://www.partsgeek.com/gbproduct...o5klPR2QfZlDLJLnMgbvJQPO5OhoCUPIQAvD_BwE
It's for a 1961 till 66 P30 chassis (I have no confirmation that this is the correct chassis other than that multiple sources have said so) and seems to have the same three bolt pattern. But 133$ is really steep for something that usually around 50/60 bucks. (I understand that demand for these are way low) eventually I would like to overhaul the brake system to something more modern. But due to time constraints I need it mobile buy the end of may 2020.
My question is are there any other Master cylinders that will swap out from perhaps other makes. I see ones listed for Ford from the same era that have what looks to be a similar bolt pattern for a third of the price.
Any knowledge is useful due to the fact that I am very new to all of this.
The idiot savant
3B Offline
Hy Grizzlynaut, welcome, the master cylinder I come up with for a 1/2 ton P series 1960 to 62 is Raybestos part number MC 34403, that is a 1 1/8" bore and uses a two bolt mounting which is offset $42.89 at RockAuto. According to my brake parts catalogue the same master cylinder is used on the C series pickups as well 1960 to 62, hope that helps.
I don’t know if your 1 ton is different than a 1/2 ton but the M/C in the photo looks a lot like the one I removed from my C-10 when I converted to power brakes.
Thanks 3B, it really looks like its a 3 bolt. I'll be back out there tomorrow. I could be very wrong on the chassis designation.
There isn't much clear information about these around. I'll look into the c-10 master aswell.
The idiot savant
Welcome to the Stovebolt wave
Check if there is a casting number on the MC...my book shows 1955-66 D-D as being 1-1/8" dia, cast # 5454736, p/n 5454644.
Is your truck a manual or automatic?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3B Offline
Hy Grizzlynaut, I apologize I gave you information for a 1/2 ton P series 1960 - 62, the number I came up with for the one ton is Raybestos part number MC21918 $127,79 at RockAuto. That master cylinder does have a three bolt mounting flange and the GM part number was 5454644 sorry for the incorrect information, I hope this new information helps.
I was able to do an Indiana Jones style paper rubbing in the narrow space between the cylinder and the wheel well.
It's indeed a 1-1/8" dia, cast # 5454736. Thanks Mike B and 3B I'll be ordering one shortly smile
The idiot savant
Riding in the Passing Lane
Have you checked it out for pits. Most of the time you can put a kit in yours.
1972 Chevy c10 Cheyenne Super
I was thinking that this was old enough for a kit but I haven't been able to locate any.
The idiot savant
It's a manual smile 4 speed with what feels like a granny 1st
The idiot savant
Or will any 1-1/8" bore kit do?
The idiot savant
It has to be a kit that is listed for that cylinder. The same kit will fit many applications. Any parts store should be able to supply it.
George
So I dropped by Napa in search of a rebuild kit and lo and behold they had the entire unit for just $48!
Thanks everyone for your help! if I ever get around to modernizing the system I'll be sure to do a write-up or something.
The idiot savant
have been trying to connect with you big bolts for 2 yrs left comments earlier but dont see them yet not a computer geek so will check back later. started with 53AD 3100 in 67 have had about 25 or 30 trucks since,drivers,6400 on down,mostly stick,worked on em for real the first time in 70 s current one is 51 6400 driver yr around truck !
You wouldn't happen to know what type of alternator I need do you? Pretty sure this one is dead.
The idiot savant
You probably should start a new thread if you want to talk about alternators, post a picture of what you have and I am sure you will get lots of help.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
