7 members (1946chevytruck, Gdads51, 55shaker, Swami29, Otto Skorzeny, 3800GUY, tclederman), 97 guests, and 1 robot.
Topics128,114
Posts1,056,604
Members48,448
#1366253 06/24/2020 5:21 PM
I thought I had this posted this a.m. There is the possibility that I did not submit properly. My 235 set with bad gas for about six weeks. The newly rebuilt model"B" only had about an hour on it, engine ran like a sewing machine previously. It was advised to drain tank. fuel lines and filters. Started on pure no alcohol white gas, ran horrible. My friend at NAPA told me to run Sea Foam in it. I did and it ran bad of coarse but then I stalled the engine. Took new plugs out and they looked fuzzy black. I cleaned them off but still will not run. A friend of mine told me to bring plugs to him and he will clean them with a spark plug sand blaster. However the cylinders are are very wet with Sea Foam. any suggestions? Doc.
If you clean the plugs with a sandblaster be very careful that you get the silica/ sand off it can score cylinders if it gets washed into the cylinders Spark plugs are so cheap I would just replace them and soak the old ones and clean them and put them back as a backup.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
It was yesterday Here
After draining, etc., did you use non-ethanol gasoline from the pump or "white gas" such as found in Coleman fuel? That's what I always associate with white gas but that term is applied to different fuels.
WE b OLD & Wally Montana thanks, buying new plugs and I buy my white gas at our local WAWA gas pump. klhansen, good to know. Doc.
Thanks again, Used baking soda instead of black sand. Could have become a big problem, your quick replies helped. Ed
I always thought Sea foam was snake oil, but I bought a Samurai that had sat for years, would die at almost every stop light, I added a whole bottle of SF after dealing with this for a month of driving it every day......,like magic it went away, IM thinking just some varnish in the tank
woof359 Family 1952 3100 5 Window
