5 members (texas46, Jaison, Hotrod Lincoln, JW51, WICruiser), 148 guests, and 3 robots.
Topics128,082
Posts1,055,961
Members48,430
Hello again,
It is proving to be a bit of a challenge to find original part numbers for some of the original components...
I am trying to confirm that the following information is correct for this truck... I am also interested in period aftermarket options, if they can be found...
1- Electrolock, or Ignition switch with protective casing and coil cover/cap...
GM 1116278 or GM 1116263?
DELCO REMY E-5895
2- Ignition Coil, single wire...
GM 1915427
DELCO REMY 536-D?
Additional Components:
1- Coil cover/Cap...
GM...?
DELCO REMY 1863090
2- Ignition switch mounting Bezel. Not quite sure how it mounts, since the outside of the barrel is not threaded...
GM...?
DELCO REMY...?
Pictured, please see the DELCO REMY E-5895...
Philippe Jeanneau
Phillip,
Not sure if this will help you but it is information I collected while restoring my 1946 (216) PU.
Harold
SHA1: 46baf38016ad8675520f1d1d08eddb42ee35559b
Harold
Y
yar Offline
Y Offline
Philipj,
Check out this electrolock grommet I just made for my '36 Chevy pickup:
https://www.stovebolt.com/ubbthread...t-3-36-all-37-46-trucks.html#Post1366584
The electrolock you're seeking is rare and expensive but they do show up rarely on Ebay. The 6 volt coils show up NOS on Ebay fairly often for $75.
Here's what an original 1933-40 coil looks like.
Ray W
Ray
Hello Harold,
Thank you for posting the photos of your electrolock for your 46... Were there any other numbers on the casting? The bezel on the lock is identical to my other 39, but I cannot find a part number for it anywhere, and have not been able to figure out how it is set, and I can't chance messing with it since I don't have a spare... If I only could see the bezel by itself I would figure it out...
The armored cable is also the same as my original but different than the Delco E-5895 I posted previously... As for your coil, I also have GM 1910405 for part number, which I imagine is the same as Delco 1115141... And Ray, as for the 1915427 coil, thank you for posting the photos, always very useful to have for reference... The correct grommet is also a nice touch. Very nice to have the right tools/set up to be able to make it...
Philippe Jeanneau
Phillip,
This may be of use to you. It looks like the cap in your photo.
Harold
Harold
Hello Harold,
That is very useful, thank you... Do you have anything on the lock end and how to remove the special style bezel?
Philippe Jeanneau
The ignition lock cylinder goes in that hole at the end. The bezel can be loosened and tightened with a spanner wrench. The picture shows what I use for this purpose with the tip going into the small hole along the edge of the bezel.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Ray W
I have a grommet like that one but it is for a 1" hole in the firewall of a 60's something GM, likely a 62 pickup. I looked around a bit on the net but did not find an actual application. I believe they were very common in the 60's for speedometer cables. I know I have seen them on many occasions.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Hello Lightholder's Dad,
Where did you get the special spanner for the lock?
Philippe Jeanneau
It was in a pile of tools given to me. Google spanner wrenches and you will find a bunch of choices much nicer than mine. From my picture you can see it is made out of thin metal; you could easily make one for yourself with a grinder and a file.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
I asked just in case... I will do a Google search for one, thank you.
Philippe Jeanneau
Does anyone know if the reproduction electrolocks once available from Tim Tygart's are being sold any place else? Thank you.
Philippe Jeanneau
