1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1366212 06/24/2020 12:23 PM
Hey all.. As I'm hooking up the throttle linkage on my 54 235 pivot point on the engine. I seem to remember there should be a spring on it so the linkage returns after pushing on the gas pedal. Could one of you shoot me a picture of yours so that I can see where to attach the spring?
Almost done putting this engine back together. I will be firing it up this Saturday. Woot Woot!!
Thanks guy's
Elmo
Elmo #1366220 06/24/2020 1:05 PM
Moderator, Electrical Bay
Mine has always been hooked at the top in the hole of the linkage tab and at the bottom I just hooked it over the lip of the oil pan. Originally there was a tab which went under one of the bolts of the oil pan, but you almost never see one of these anymore. Who knows when mine was lost?
~ Jon
Elmo #1366226 06/24/2020 1:47 PM
Do you know the part number for this spring? I got one from Jim Carter recently, but I don't think it's the right one.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Elmo #1366230 06/24/2020 2:25 PM
You can go to your local Ace hardware store and get similar springs that will work just fine.
Thanks Jon G. That’s very helpful!
Elmo #1366243 06/24/2020 3:22 PM
Yes for getting the spring at your local hardware store. You can then modify as needed the spring ends, etc. Depending where you attach the bottom end of the spring, will determine how long the spring needs to be.
Craig
