3 members (Gib70, Woodcmiami, Danielbolt), 318 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
#1365024 06/15/2020 11:02 PM
I hate to ask about this because I've spent some time searching trying to find the VIN on my truck, but I need help. Any suggestions from those that have Big Bolts on where I can find the VIN for my 1957 GMC F350 LCF?
Thanks for any input and sorry if this has been addressed somewhere else on the forums.
57 GMC F350 Shortened WB 6' added 8' bed.
Interesting truck you have there!
Welcome to the Bolt!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Sir Searchalot
Sir Searchalot
Sould be on driver door hinge pillar. Check inside glove box door. If it nowhere to be found, it's been removed. Seems like a hybrid truck. I think GMC called them LCF. Low Cab Forward.
Crusing in the Passing Lane
Chevy called them LCF's, GMC called them 'F's'. What engine do you have? Nice that you kept the big wheels, would look undernourished in the fenders if 16's used.
Ed
Check the top of the frame rail, left side above the front axle, it should be stamped there as well. May require a wire brush to see it...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Sir Searchalot
Sir Searchalot
As far as I know, GMC did not stamp the frames but who knows what frame he has.
Apparently GMC stopped stamping frames, someone on here knows when. My '37 has it stamped top right of frame just inside front wheel, right side.
Ed
Sir Searchalot
Sir Searchalot
Not stamped in his era. The GMC frame stamp, which is on the front passenger side, specified to be on the side of the frame, corresponds to the Serial/Data plate being on the cowl. When GMC went to drivers door hinge pillar plate, no stamp. Looks like mid 1949 transition period.
It's not on the door pillar or in the glove box.
I'll start looking for stamps on the frame, maybe I'll get lucky.
This truck has the straight 6, I'm assuming it's a 270. I shortened the frame about 6 feet and moved the axle forward to put a bed on it and use it as a project truck around the house.
Sir Searchalot
Sir Searchalot
I assume you are trying to find the Vin plate to get it titled? There will be some holes on the drivers hinge pillar where the plate was.
Could be a GMC 302 straight six, I've got one in my 450
'52 Cadillac Coupe de Ville (to be restored)
'56 GMC 450 (work in progress)
'79 GMC C15 (fully restored)
The engine displacement on an old GMC 6 cylinder engine is usually part of the Engine Serial Number that is stamped into the ledge in the block at the rear of the distributor.
I found a 302 in one a while back.
Ed
I'll look there to verify the engine size and see what I find.
