5 members (Stovebolt48, Rmillerfly, Shaffer's1950, 2 invisible), 93 guests, and 1 robot.
Topics128,050
Posts1,055,758
#1364808 06/13/2020 9:38 PM
I am installing a electric fuel pump on the old truck (59 with a 235 . Was wondering if a inline filter should be between the tank and pump or pump and carb. This does not have the glass sight filter at the carb. Was thinking of one of the steel/alum filters with the replaceable filter.Pump is close to tank.
I'd want to catch the trash before it went into the pump...
What electric pump are you using? The one I have on my fire engine is a Faucet and I've had good success with them, but I still carry and NIB pump with me at all times.
I rigged the electric connections at the pump with pull apart connectors and have the new pump with a connector already installed making on the road replacement fast and easy. They will ALL fail at some point...
Why aren't you using the mechanical pump on the 235?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I have a faucet cube pump. works good just thought a filter would keep the rust/crud outa the carb. The orig pump was gone when i got the truck but it had a electric from a car hooked up but badly. so i mounted a cube pump back by the pass door on the frame . Now am replacing the tank and thought this would be good idea. on your pump does it have a pressure shutoff? mine does not and some times overwhelms the needle valve.
59',
If period-correctness isn't a concern, I like to use Holley regulator 12-804 (adjustable 1-4 psi), which is relatively inexpensive and works well with electric fuel pump setups, and would solve your "flooding" issue. With this type of setup, a small mechanical fuel pressure gauge near the carb is nice to have, and there is an extra port on the Holley regulator that can be used for one.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
The pump I use has an internal pressure relief system to prevent pressure when it's not running.
https://www.pegasusautoracing.com/p...tF9iF88oXJfaiV4MD8sOIEL9IwBoC3MoQAvD_BwE
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
