1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 328 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 328 | Hello All,
Would anyone know the correct AC Delco model or GM number for a 2 post, 6 volt generator on a 1939 VC model truck? Engine has a 6-1/8" mounting bracket... Thank you.
Philippe Jeanneau
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2019 Posts: 328 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 328 | Hello there,
Thank you for the link, looks like a 934 F should be the one... I better double check the voltage regulator and starter also.
Philippe Jeanneau
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I read that link as indicating the standard generator for a heavy duty truck as 948R, with the 934F as an R.P.O (regular production option). And, the standard heavy duty truck has no voltage regulator, which means it would have a voltage cutout only. The asterix in the R.P.O. box takes you to the bottom of the page which indicates you could get a voltage regulator with current control. Bottom line is you have more choices to keep it "correct". Kent | | | | | Joined: Jan 2019 Posts: 328 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 328 | Hello Kent, I see how I missed that, so the difference between the "Regular" 948R, and the "Regular Production Option-RPO" 934F option is a single post with cutout, or a 2 post unit with a voltage regulator? My other 39 (VB) 1.5 ton has a 948R with a cutout, this one has a voltage regulator that appears original...I will have to inspect what is left of the wiring harness... The other clue is the generator mounting bracket which is about 6-1/8" long...
Philippe Jeanneau
