7 members (Gdads51, TUTS 59, mk72, ShopRag, Stovebolt48, Hush, Otto Skorzeny),
117
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13645 02/14/2005 10:09 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | Ok, I just got my Pennrite Steering box lube. Since this stuff is SO thick what is the best way to get it into the box? Also how much should it take? | | |
#13646 02/15/2005 2:18 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A ziplock bag with a corner cut out makes a pretty good "grout bag", just like cake decorators and tile layers use. Just fill the bag, zip it up, and snip the corner and feed it into the fill hole.
#13647 02/15/2005 2:46 AM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | Did you warm it up some how? | | |
#13648 02/15/2005 2:55 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Hi Thomas,
I just left the container in the sun for half an hour ( although it is the middle of summer in this neck of the woods) . You could put the container in a bucket of hot water. That should make it flow a bit better. I filled mine with a small funnel in the top of the steering box and a length of wire coathanger to agitate down the spout of the funnel. Worked fine.
Bob | | |
#13649 02/15/2005 5:54 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | You must have got the older style boxes. The new ones have a pop-up spout that you just pull-up on. Put the spout into the steering box and squeeze. Very easy to use. Sorry this doesn't help your situation, but I thought I let future buyers know that it's easier than it use to be. Cecil..... | | |
